Keep Losing Sync
- This topic has 3 replies, 2 voices, and was last updated July 16, 2016 at 10:42 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Keep Losing Sync
So I’ve been testing the device with my Samsung UN65JU7500, when I keep the image still it works fine but as soon as the screen scrolls. The TV loses sync, it’ll come back and it’ll lose sync again. I messed around with LPF setting still drop outs. Changing the analog sync to 2.5mhz keeps it on longer but still unusable.
Which console are you using?
Super Nintendo(NTSC) yeah, I pulled out my genesis and it worked fine. I ended up making a Luma sync snes cable, it works fine but now my bvm won’t sync. Going to see if i can find a snes that works with a Csync cable and the ossc.
I am using a bnc splitter between the BVM and ossc. The csync worked fine apart from the dropouts. The genesis works fine. Now with the luma sync snes cable bvm doesn’t work.
Fixed the C sync wire was grounded, error on my part. Works great. LUMA sync on snes is a must.
