Koryuu not recognising signal after previously working
NewHome Forums Koryuu Transcoder Koryuu not recognising signal after previously working
  • #41430
    Carn
      It worked fine at first, now for some reason the Koryuu will only send its own signal of the coloured bars to the OSSC ignoring the NTSC N64 I have plugged into it. Have I done something wrong here? I don’t know how to fix it. Resetting everything hasn’t made a difference.
      #41437
      megari
        First, let’s check a few basic things:
        • What input are you using on the Koryuu? (composite/S-Video)
        • Does that input match the current input setting?
        • Please check and try reseating the video cable between the N64 and the Koryuu.
        • Have you modified the Koryuu unit in any way? Have you updated and/or altered the firmware? If so, would you mind providing your changes to aid debugging?
        • Is the N64 modded in any fashion? If so, how?
        • What kind of video cable are you using between the N64 and the Koryuu? Where was it bought from? Is it an original Nintendo cable?
        A sudden failure to work does sound like some piece of hardware may have failed, unless it is some sort of a settings issue. The questions above are the first step in trying to narrow down the cause.
        #46174
        KSzeims
          Hello, was there any resolution to this issue? I’m having a similar issue with my Koryuu:
          What input are you using on the Koryuu? (composite/S-Video) – Composite
          Does that input match the current input setting? – Yes. And I’ve cycled through all 4 input options, and even upon resetting the power (which should set input to default – Composite) the same issue persists.
          Please check and try reseating the video cable between the N64 and the Koryuu. – I have reset the cable on both the Koryuu and N64 ends. Same issue persists.
          Have you modified the Koryuu unit in any way? Have you updated and/or altered the firmware? If so, would you mind providing your changes to aid debugging? – I have not updated or modified my Koryuu in any way.
          Is the N64 modded in any fashion? If so, how? – It is not modified.
          What kind of video cable are you using between the N64 and the Koryuu? Where was it bought from? Is it an original Nintendo cable? – It is an original N64 Composite cable.
          This unit arrived this week, and worked once perfectly before only displaying bars the next day. Thank you.
          #47406
            Sorry for missing this! If you’re still having issues please contact me through the website contact form.
