Legacy AV In for OSSC Pro
- This topic has 17 replies, 5 voices, and was last updated November 5, 2025 at 11:23 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Legacy AV In for OSSC Pro
The extra section can be cut off as long as nothing gets shorted due to sawing. GND connection via terminals should not be mandatory for the legacy AV card which still runs at relatively low frequency (2 pins from the IDC are reserved for ground). Retrospectively a PCIe connector (like this) would have been a better choice due to more pins available for GND, but screw terminals would have been needed anyway for fastening cards.
Finally got all the bits together to make the extender…
But it doesn’t seem to be very effective. Tested with a NTSC NES (To be more accurate, a PAL NES with NTSC PPU, CPU and crystal). Colours initially were correct but degraded after a few seconds. All the while with flickering green lines and generally unstable.
I’ve verified that all 50 pins are connected with no shorts. This was not my first attempt, the previous one had a slightly longer cable and the result was there was practicality only green lines.
Works fine when plugged in normally, so I think I can rule out accidental damage but it’s not a deal breaker that it doesn’t work. More a experiment than much else. I may consider the possibility of mounting and connecting the AV in PCB internally in exchange for removing the expansion socket… but I think I’ll wait out my warranty before I think about doing that. ^_^
While testing RF-equipped Legacy AV board I noticed similar issues with IDC50 extension cable, even short one. It appears grounding / signal integrity degrades enough to cause visible problems.
