Line 2x and 480p passthrough dropping signal to CRT Monitor
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Line 2x and 480p passthrough dropping signal to CRT Monitor
  • #22740
    Abwezi
      Hello! I’m wondering if anybody may know what might cause this issue. I’m trying to use my CRT Monitor, a Mitsubishi Diamond Pro 2070SB, and all other modes gives a constant picture to the screen. When I choose either line x2 for 480i and under content, or 1x passthrough for 480p, my CRT monitor will recieve the picture at first however normally about 10 20 minutes in to playing my monitor will stop accepting the signal unless I switch the OSSC to a different mode and then back.
      #22743
        what kind of HDMI to VGA adapter do you have?
        #22754
        Abwezi
          I’m currently using the Tendak active female to male adapter
