I’ve tried the same thing briefly and it does work fairly well, although I imagine the HDMI input on the OSSC Pro could be sensitive to jitter and require tweaking in the OSSC just like with displays.
There could also be limitations with higher scaling modes from the OSSC Classic, but there of course it can be set to a lower scaling mode or passthrough and let the OSSC Pro handle the scaling.
One of the limitations is that internally, the OSSCs can combine an unusually high sample rate with a low line rate to oversample the input, but that cannot be carried over from one OSSC to another over HDMI outside of using corresponding scaling modes before sending things across.
So passthrough of e.g. 240p won’t be higher than the normal ~860 samples per line while 2x or 4x modes can be higher. With 480i and 576i you may want to use passthrough to take advantage of the OSSC Pro’s adaptive deinterlacing in Scaler mode, but then too you’re limited to the OSSC Classic using a lower sample rate.
It can also get confusing when tweaking each OSSC as their menus have the same color scheme.
But with all those things considered, there’s no reason not to test it and check what works. 🙂
