MiST-Fpga with OSSC
Viewing 15 posts - 1 through 15 (of 16 total)
  • #16185
    uchristo
      Hi Folks!
      I’m trying to get the minimig AGA Core on my MiST Fpga working with the OSSC. Unfortunately, my TV (a Panasonic TX-L37EW5 from 2012) won’t work with any of the LX3,4,5-Settings 🙁
      The MiST is configured to disable the Scandoubler, so Output from it’s VGA is shown as RGBS 313p @ 15.79kHz, 50,47Hz, whilst Output from OSSC is set to VMod 288p, LC313, VSM 2
      But I’ve got another problem…. First of all, the OSSC has to be switched on and set to “AV1: RGBS” prior to powering on the MiST. Otherwise, the OSSC won’t get sync. The upper half of the resulting piucture is pulled to the left and flickering, the lower half is rock solid. I can solve this by lowering VSync Threshold below 5.0us until the sync is lost. Adding threshold to 5.07 will regain sync and the upper half of the picture is solid, too.
      The problem: I have to do this every time I power on the devices. Any solution for this?
      #16210
        The digitizer chip has issues with non-interlace signals using odd-odd field signalling (identified by VSM=2). One solution is to hook the source to AV3 VGA input (doesn’t MiST already output VGA?) which has a bit different sync processing chain and doesn’t inhibit this issue (but has a few other bugs).
        #35584
        uchristo
          It’s been some time, I got a new TV and got it working in Non-Linedoubled mode with one Caveeat. I have to replug the Source many times before the OSSC would sync. I now wanted to try out the Scandoubled output of Mist FPGA via RGBHV on AV3.
          My problem:
          Non-Scandoubled output is being correctly recognized as 288p
          AV1_288p_Default
          AV1_288p_Info
          and via lx4 with H-Active 1920 and V-Active 270
          AV1_288p_LineMode
          AV1_288p_AdvTiming
          there’s a stable picture (but unfortunately shifted to the right (I made use of Horizontal Mask to show this).
          AV1_288p_Picture
          The Linedoubled Output on AV3 is unfortunately recognized as 800×600
          AV3_800x600_Default
          AV3_800x600_Info
          I thought this would be 480p/576p, which I would then lx2 to H-Active 1920/V-Active 540 to get 1920×1080, but how???
          AV3_800x600_AdvTiming
          There’s no possibilty to set some sort of Linedoubling for 800×600….
          Edit: My pictures (added via ibb.co) aren’t displayed?!?
          #35605
          uchristo
            Got the Pictures working….hooray!
            #35609
              It’s kind of surprising those resolutions work I think the Amiga must be the only machine that ever output 800×600 at 50hz. If you went to 800×600 60hz on your old TV it probably would have worked.
              800×600 cannot be linedoubled. If you’re emulating AGA there weren’t many games that took advantage of anything high resolution as AGA was really slow with high res colour modes sadly.
              #35613
              uchristo
                You misunderstood…. inserting the Pictures into the Reply worked now. The Problem itself persists.
                The MiST doesn’t output 800×600. It linedoubles it’s 288p-Output, which is recognized as 800×600 by OSSC which isn’t correct. The OSSC should indeed recognize the Signal as 480p/576p!
                #35749
                uchristo
                  Is this behaviour (Selecting 800x600 rather than 576p for Linecount=626) a bug? How to proceed? Is there a possibilty to manual switch the output mode to 576p?
                  #35871
                    Ok so you’re saying you want to line double with the mister then line double again with OSSC? Why not just output native from Mister and use OSSCs line multiplication?
                    #35921
                    uchristo
                      Hi Bucko,
                      it’s no MiSTer (HDMI onboard), but a MiST (with VGA in 15kHz/31kHz)
                      The OSSC cycles through it’s inputmodes (very(!) fast), but it does not sync. I have to replug the Source (AV1) multiple times to get the OSSc to Sync to what is shown in the first picture in https://videogameperfection.com/forums/topic/mist-fpga-with-ossc/#post-35584 .
                      This is quite annoying. So I thought, lx2 576p should be the same like lx4 288p, but maybe without this annoying replugging.
                      #36157
                      uchristo
                        Just to show you what happens, when I connect the non-scandoubled MiST with Minimig AGA Core running:
                        Powering on the MiST
                        The Sync won’t get stable until I replug the MiST after it’s fully booted. But even then I have to replug it several times until sync is getting established.
                        Don’t mind the noise in the background. It’s just the coffee machine 🙂
                        #36268
                          Wish I had a solution for you but all I can say is this doesn’t happen on a real Amiga.
                          #36274
                          uchristo
                            Well, that would be no issue if I could use AV3 for the linedoubled Output to double again into a 1920x1080p-Frame. But the scandoubled Output gets misdetected
                            #36275
                            uchristo
                              Is there some kind of serial Port on the OSSC to debug this issues in 15KHz-Mode?
                              #36549
                              uchristo
                                Who could help here? I guess, there’s some simple elseif-Statement on the linecount which decides the mode to choose?!?
                                #40728
                                uchristo
                                  One step taken, the next to follow….
                                  I re-enabled the Scandoubler on MiST, soldered a VGA->YPbPr-Cable and hooked this up to AV2 of OSSC.
                                  I now dialed in the following numbers:
                                  Linemultiplication-Mode for 480p/576p: 2x
                                  H. Samplerate: 1362
                                  H.Synclen: 64
                                  H.Backporch: 243
                                  H.Active: 960
                                  V.Synclen: 5
                                  V.Backporch: 64
                                  V.Active: 540
                                  Sampling Phase: 258°
                                  Picture is stable and uses the whole 16:9 Screen.
                                  I then wanted to try out the differences when changing Line2x mode from “Generic 4:3” to 320×240 or 256×240(++ 256×240 aspect 8:7)
                                  The changes seem to have no effect? Is this setting only available for 240p-Sources?
