Mister DV1 Game Gear, Gameboy and Lynx cores
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support Mister DV1 Game Gear, Gameboy and Lynx cores
  • #64922
    onthewaveagain
      Hi Marqs, have noticed some sort of video garbage above the picture with the Gameboy, Gamegear and Lynx mister cores in DV1 mode. Not sure whether this is an issue with the data passed by the core or the OSSC pro not properly interpreting (croping?) these small resolutions.
      #65040
        I was unable to replicate this here, what settings are you using?
        #65046
        onthewaveagain
          Adaptive LM, but it looks like the problem is with the output resolution. with 5x the garbage is not visible while with the 6x resolutions it is visible (with both 2560×1440 and 1920×1440).
          Also, I noticed the function Marqs implemented to rescale when you open the core OSD does not work properly with the Gameboy core. Picture shifts right completely.
