Modify Dreamcast RGB Scart?
NewHome › Forums › RetroTink Products › Modify Dreamcast RGB Scart?
- This topic has 10 replies, 2 voices, and was last updated October 1, 2022 at 3:19 PM by Thanius.
April 14, 2022 at 1:38 PM #52931
Hi, so I’m in a bit of a pickle.
I previously had an OSSC to hook up my Dreamcast using SCART. Great picture, no sync loss or anything, been playing like this for the past 2-3 years.
Now I’ve recently upgraded to a Retrotink 5X Pro and I can’t use the same cable any more as it has flickering image, and I’m afraid to blow up my setup.
I then ordered a VGA/RGB cable with switch from eBay, but that cable isn’t compatible with my Dreamcast as it’s modified with a Dreampower PSU (not DreamPSU) and it seems like the cable is drawing too much power for the setup as the sound is really weird, like the CPU is being affected or something.So my question is, can I modify my old cable with a resistor and capacitor? I can’t find any guide specific for Dreamcast so would be nice if someone could point me in the right direction.
Cheers!
April 14, 2022 at 1:53 PM #52932You have a flickering image, can you elaborate? A flickering image is not indicative of a cable that will blow up your system.
OSSC requires a 75 ohm terminated SCART cable the same as the RetroTINK 5x does. You can open the SCART end of this cable and see if it has any components on the sync connection.
VGA boxes do not draw more power, it seems to me like your Dreamcast may have some other issues.
April 14, 2022 at 2:12 PM #52933Hi, hard to explain. The image is nice and clear, but in the middle it’s like glitchy and pulls to the left. I’ve got a video of it I can put on YouTube. Anyways, I just opened up the cable and all there is are a capacitor on each RGB line, rated 220uF/10V.
Nothing else, so it’s strange that it worked flawlessly on the OSSC (but come to think of it, it would lose signal once in a while.)
How should I modify the cable?
April 14, 2022 at 2:14 PM #52934My Dreamcast is modified not only with a new PSU but also GDEMU clone.
April 20, 2022 at 11:27 AM #53013Here’s a video of the output
So all I need to do is solder 450ohm resistor and 16v 220uF capacitor to pin 21?
April 21, 2022 at 6:43 PM #53034Well, wait a moment, are you sure the cable is even using composite sync, and not composite video for sync?
April 21, 2022 at 7:28 PM #53037I have no idea how this thing’s wired more than it’s only got capacitors on the RGB lines. Is there a schematics somewhere I can follow to properly wire it?
The weird thing is that the cable works perfectly fine with OSSCApril 22, 2022 at 12:13 PM #53048Where did you get the cable from for starters? Unless you specifically got a cable wired for csync, it’s likely to be composite video for sync. You could confirm with a multimeter I think, http://members.optusnet.com.au/eviltim/gamescart/gamescart.htm#dcast
April 22, 2022 at 12:19 PM #53049It was mostly purchased from eBay gazillion and a half years ago. I’ll check that link and see if I can verify the wiring.
I should be able to rewire it on the Scart side, right?
April 23, 2022 at 12:43 PM #53058Almost certainly it’s composite video for sync unless you specifically looked for a composite sync one. No, if you want to modify it for composite sync you’d need to change the Dreamcast end.
However, RetroTINK 5x is perfectly compatible with composite video for sync.
I have to suspect something strange going on with your Dreamcast based on what you told me about the other cable you purchased. Can you try another Dreamcast with the same cables?
October 1, 2022 at 3:19 PM #55123Some news on that new cable I bought, which I thought was incompatible. Turns out, after some research, that the pins on the motherboard to the PSU had oxidized and was making bad contact on some pins which caused the symptoms.
All I had to do was add some solder to the pins and everything’s working as it should with the VGA cable. However, the retrotink was misbehaving in scart mode (it didn’t quite sync with the interlacing, causing stripy patterns) so I left it on VGA mode instead. Works great, now I only need to patch Skies of Arcadia since I’m running my PAL version. -
