Morph4K Firmware 3.6.2
NewHome Forums PixelFX Products Morph 4K Morph4K Firmware 3.6.2
Viewing 1 post (of 1 total)
  • #60993
      Morph4K Firmware 3.6.2 is now available (all update channels).
      Motion Adaptive Deinterlacing: Changed default sensitivity and added menu option to configure it in three steps (“low”, “normal” (default), “high”) (OSD->Video->Deinterlacer->Sensitivity when motion adaptive is selected)
      Morph4K: Fixed direct video on MiSTer cores that used line lengths greater than 4K pixels
      Genesis/Mega Drive, TG16 etc.
      Morph4K: DV1: mask pixel repetition when menu is open
      Morph4K: Updated default input EDID to properly indicate multi channel audio support
      Morph4K: Fixed pixels on right and bottom
      Notes on MiSTer direct video DV1 support:
      To enable DV1 auto adjustments, set OSD->Video->Advanced Video->RX DV1 mode to on (Currently the default is off, but this might be changed in a future firmware update)
      With RX DV1 mode set to on:
      Not all cores are updated to send the proper DE offsets yet.
      There is no meta data to indicate aspect ratio in the DV1 information. Morph is therefor assuming a 1:1 PAR for DV1 sources.
      With `RX DV1 mode set to off:
      The input data area includes black borders as added by MiSTer in direct mode, so aspect ratio and scaling might not be correct in regards to the actual active pixels in the game.
