MVS – sync and test pattern but no output
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support MVS – sync and test pattern but no output
  • #67603
    chumley
      Hi, I’m new to all of this but I have a MVS Neo Geo, RGB via scart, I get picture if I directly connect to a TV (1080p Sony led) but I cannot get anything via the OSSC (apart from test pattern), on either that TV or any other TV or monitor I have (tried 4k Sony OLED, 4k OLED PC monitor, LED PC monitor, Panasonic Plasma).
      I get sync : AV1_RGBS 264-p 15.62k.Hz 59.19Hz but after clicking the button to activate it I get black screen / no signal.
      Can someone please help?
      • This topic was modified 3 weeks, 6 days ago by chumley.
      #67610
        Are you using an RGB cable? You must use a fully wired RGB SCART cable (or component video cable) with the OSSC, you cannot use composite video without a transcoder.
        #67611
        chumley
          Yes full RGB from ths7374 cmvs RGB board with a known working, good quality cable
          • This reply was modified 3 weeks, 5 days ago by chumley.
          #67612
          chumley
            #67613
              Have you tried these settings? From what I remember, Panasonic plasmas at least do not tolerate 2*264 = 528 line signals by default. 0.xx firmwares had a hack to make them working with these, but was left out in the transition to 1.xx series. It’s due to make a comeback soon, though. 59.19Hz is another thing that some TVs do not handle.
              #67614
              chumley
                **Sorry double post**
                #67615
                chumley
                  I have put these settings on, they didn’t work but it took longer for it to say no signal.
                  The main TV I’m using is a Sony KD-55AG9 (OLED)
                  #67619
                  chumley
                    I upgraded from 1.11a to 1.12.
                    Imported firebrandx Neo Geo profile.
                    Altered H-PLL pre and post coast to 2 lines and it works!!!
                    #67620
                    chumley
                      #67624
                      lordformat
                        Thansk guys, for the settings, and i’m glad to see  run correctly  Thanks to Marqs and Matt for support.
                        ill make a a tiny link to this post  with the future manual of my cmvs
