The menu button on the remote for my OSSC has randomly stopped working, the green LED on the OSSC doesn’t flash when I press the button. However all the other buttons work fine, I can change the source with the number buttons, enabled/disable scanlines, increase/decrease their strength, enabled and disable the OSD light, etc. Is this perhaps an issue with the OSSC or the remote? My OSSC has v1.6 software installed if that helps. I also made sure to press the TV button although all the other buttons are working fine so this obviously isn’t the issue here.
