N64 : Problem with Retroverse S-Video cable
NewHome › Forums › General gaming › N64 : Problem with Retroverse S-Video cable
  • #48251
    Gaetan
      Hello,
      I have just gotten a Retroverse S-Video cable for my N64. It’s PAL and the motherboard revision checks out with what is written on VGP. It is plugged into my RetroTink 2X-Pro. Audio goes through just fine, but I am having issues with the video signal. Most of the time it doesn’t register at all. I have to wiggle the cable on the N64 end in order for it to appear, and then not breathe too hard in front of it.
      Is this a problem with the cable, or my N64 ?
      Thanks.
      #48264
      Gaetan
        I will try this weekend to clean the inside of A/V port with 99% isopropyl alcohol and also reflow the solder on the connector. I’ll post an update when I’m done.
        #48266
          Ok let me know how you get on, I’ll be happy to swap the cable for you if you think it’s that at fault after such extensive troubleshooting.
          #48287
          Gaetan
            Ok I tried all that and the problem is still there. Unfortunately I don’t have another N64 or S-video cable to try so I’ll email you.
            #49382
            Gaetan
              Just in case anyone stumbles onto this topic, the problem was with the cable itself. Matt sent me a new cable that’s been working just fine.
