I’ve just ordered the N64 RGB amp Rev 1.2b. I’m doing my homework on the installation before it arrives. The product page and installation instructions make mention of the -03 and -04 boards, but not -02. I examined my board and confirmed that the stock CSYNC components are installed and wired-up to pin 3.
Does this amp require removing the existing components to use buffered CSYNC? Or does the stock wiring do what’s needed and then I just leave J3 open?
As a point of comparison, I was reading the installation instructions for the Voultar amp which clearly says if you have have the buffered CSYNC wiring installed in your board, you don’t wire-up the sync cable or do anything else. https://voultar.com/N64RGB%20Installation%20Guide.pdf
FWIW this is an NTSC-J system, I’ve ordered an SNES NTSC SCART cable, and will use it with OSSC.
