N64 s-video cable on ossc
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › N64 s-video cable on ossc
- This topic has 4 replies, 3 voices, and was last updated May 23, 2018 at 3:39 PM by
nmalinoski.
May 22, 2018 at 12:56 PM #21804
Hi
Another N64 RGB question that im sure people are tired of however i have a PAL N64 un-modded with a modifeid s-video cable.
http://www.robwebb1.plus.com/n64/n64.htm – N64 S-Video & AV cable – PAL versionI dont suppose thie cable could “in theory” be made to work with the ossc using a modified s-video to scart or s-vid to componant adapter? I have seen some talk about the possibility of a device that could turn a signal into RGB but what if it was an s-video signal would the goal posts change a little or not at all?
I understand why the ossc only accepts an rgb signal a bit but there must be other N64 users with pal only machines they have had since release, in the market for an affordable fix that isnt console modification.
May 22, 2018 at 2:11 PM #21807S-Video to SCART adapters are all passive, so you’re just changing the connector and doing nothing actually convert the signal to RGBS or YPbPr. An S-Video to component converter (not adapter; needs to be a box with circuitry, like this thing) would work, but I can’t speak to their efficacy.
You can also try tracking down an RGB decoder. I have a Kramer FC-4044 that works quite well in decoding composite video and S-Video to YPbPr/RGsB component and RGBS. Unfortunately, these things are very hard to come by; good luck finding one.
I would say the best solutions would be either:
1. The RetroTINK 2X, which accepts composite, S-Video, and YPbPr component, and outputs HDMI. It’s a very basic scaler, compared to the OSSC, but it, importantly, has compatibility with composite and S-Video. You would need to either forego the OSSC, or get an HDMI to VGA converter (which would be a bit silly, going from analog to digital to analog to digital); or
2. N64RGB modification, either borti’s or Tim Worthington’s, so you can actually get RGBS out of the console, and apply some deblurring compensation; or
3. UltraHDMI modification, for the same reasons as the N64RGB, just with HDMI out instead of analogue RGBS.May 22, 2018 at 4:55 PM #21810Anonymous
+1 for Tim’s N64RGB board. Just installed it on my N64, replacing a simple home-made 7314 amp. The deblur is a noticeable improvement.
I’m sure borti’s is equally good, but I don’t have personal experience with that one.
May 23, 2018 at 1:03 PM #21820Yeah, well thanks for the replies. Shame there was not a solderless solution but il look into RGB amps.
May 23, 2018 at 3:39 PM #21822You can fully blame Nintendo for the lack of a solderless solution; had they simply maintained port spec with the SNES, this wouldn’t even be an issue.
Do keep in mind that the simple $30 RGB amps are only for early N64s that start with NS1, while the boards by Tim Worthington and borti will work with any N64.
