Need help to get SNES working
  • #9835
    LeGionellz
      Hi all,
      I received my OSSC yesterday and I can’t get my SNES to work on my Sony HDMI TV (an oldie, 5-7 yrs). When I turn on the OSSC I get a sort of a testscreen (with grey fields, etc) and when I turn on my SNES, the TV screen turns black. On the OSSC display, I see that there is sync and the light turns green. So it seems to recognize the signal.
      When can I do to get this working ? I have been reading a lot of older posts on several forums, but can’t find any helpful info. Would be great if there is a FAQ, or and overview of options that I should fiddle with. Or if I need a certain FW that is more compatible, that’s also fine (I read that somewhere)
      Many thanks in advance for your help !
      #9836
      paulb_nl
        Which cable are you using? What kind of SNES (PAL/NTSC)? Is the screen on the TV completely black so no OSD text?
        You have not read the Essential resources on this forum?
        #9842
        LeGionellz
          I’m using a csync cable, also tried a regular one and a component cable. Csync is the one that should work for sure.
          The snes is NTSC (snes mini) and the screen turns completely black when I switch it on. So no text or anything about a signal.
          #9844
            Have you tried a different display? Some TVs are not compatible with SNES and OSSC.
            #9846
            LeGionellz
              I don’t have another display, but are you saying that a black screen means that my display is not compatible with the OSSC, period ? So it’s no use to try different settings ?
              #9850
              paulb_nl
                A black screen could also mean the RGB signal is not reaching the OSSC but it would be strange if both your scart and component cable are not working.
                Sync LPF is the main setting to try. Can you also try to connect a composite video cable to the green AV2 connector and see if you get something on the TV?
                #9852
                  Have you tried another console besides your SNES?
