Hi guys,
loving my OSSC so far but I’ve got a little bit of a dilemma.
I’m mostly using it with my Dell 2007FP monitor, it’s a lovely image and takes 5x 1600×1200 like a champ. I then split the HDMI to that and my capture card.
But, it will only display an image if I put the output to DVI mode, which drops audio from the hdmi output. With my current capture card, I have an audio in 3.5mm so I use that instead. But, my card won’t accept much other than 2x modes, so I’m looking to upgrade but cards like the Livegamer 4K (which I’ve heard loves the 5x mode but I can’t find if it’ll take the 1600×1200 version) don’t have a separate audio in line. So I’m not sure how to get audio back into the HDMI signal.
I’m wondering if there is a solution to this. I’ve tried splitting to 2 HDMI using regular HDMI mode, and using a converter for the DVI but had no luck with some of the 10-20 dollar amazon products on the Dell 2007fp monitor.
Thanks
