Neo Geo AES S : 20k/30k Top Screen Pb (Sync ?)
- This topic has 0 replies, 1 voice, and was last updated January 14, 2017 at 1:15 PM by .
Viewing 1 post (of 1 total)
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Neo Geo AES S : 20k/30k Top Screen Pb (Sync ?)
Hi all
I have recently own a NeoGeo Aes with “armouring” all in the Inside (serial between 20k/30k, the sticker was taked off…), great piece of hardware, sharp rgb signal but…
When I use it with the OSSC (and the FM by the way), I’ve got a distorted picture in the top of the screen like that :
__
Hooked it directly to av1, using a sync strike (or xsync) in av2, using my xselectd4…always got this annoying distortion…
Tryed to adjust ossc’s timing and sync option but nothing seems to arrange that
For now the console is away in my friend’s house (to check the motherboard), do you guys know if I have to mod the signal of the console (I have read that on some neogeo that the sync is not properly wired…)
Mant thanks !!
