Neo Geo CDZ
- This topic has 5 replies, 2 voices, and was last updated September 2, 2018 at 2:31 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › Neo Geo CDZ
Hi all,
Just getting my new OSSC setup. First issue was no sync from my Turbo Duo. Resolved that by setting LPF to 10MHz. I’m not having any luck with the second issue. My Neo Geo CDZ syncs and shows an image but when playing games I get bad tearing across the screen. It’s like playing a PC game with vsync disabled. Are there any settings I can change to fix this?
Thanks,
mario64
That could be down to your display. What refresh rate does the OSSC report for the console?
59.59Hz. I’m connecting to a Samsung KU6290 4k set
Update: the issue seems to only present when using line5x. If I drop down to 4x it’s ok. My other systems don’t have this issue with 5x. Any idea why the CDZ does?
59.59 is a fair way off spec though I thought Sammys were a little more tolerant to that kind of thing. Which 5x mode are you using, 1080p?
Happens on any 5x mode
