NES Clone AV cable
  • #10159
    cctron
      Recently I’ve received the ossc converter, it works incredible with all my consoles, but with one in particular I’m having some troubles. I have a MX Onda, which is a NES clone, MxOnda, it works fine in a TV with an AV cable and a Scart adapter, but it doesn’t work with ossc. May I have to do a RGB mod? I have seen the NESRGB but I have doubts about if this mod will work in my NES clone.
      Thanks in advanced.
      #10196
        OSSC only supports RGB, to use composite sources you must use a transcoder first.
