[Newbe] N64 NUS-001 (FRA)/Gamecube – signal drops
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support [Newbe] N64 NUS-001 (FRA)/Gamecube – signal drops
  • #35767
    ovoxRubenxovo
      yesterday i connected my N64 NUS-001 (FRA) “modded” console via. RGB cable to my OSSC.
      First I tried the x5 Mode but the image height is too much (10% cut off on the top and bottom of the screen).
      Then i tried the x2 Mode … the first image was flawless, perfect fitting on my TV (Samsung Q84R 4k) … aaaaaaand it’s gone.
      As soon as i use the x2 mode the image stays for ~4-5 seconds and then the signal drops (black screen, no sound), the signal returns after 1-2 seconds but then it drops again and so on.
      The indicator light on the ossc stays green. I tried the console and cable on a older tv and it worked (ugly af but worked).
      The same problem is with my Gamecube but not so often, maybe once every 1-2 minutes.
      Also with some games the ossc dosn’t get any signal from the n64?!? (e.g. Mario 64 or Majoras Mask)
      What settings do I need for the N64?
      Thanks
      #35770
        Who did the mod on your N64 and what kind of mod is it do you know?
        #35773
          Are you using quality cables or some junk off ebay?
          #35774
          ovoxRubenxovo
              Clearly mediocre quality, apparent from the reviews. I’d recommend cables from retrogamingcables.co.uk instead.
