Having a look at the Super CIC ++ docs:
“You can also connect the buffered output to pin 7 (for use with sync-on-luma cables). Just remove R19 instead of R28. Same if you want to wire the buffered output to pin 9 (for use with sync-on-composite video cables). Just remove R18 instead of R28.
In both cases, close SJ93 for proper signal attenuation.’
So it seems like R18 is connected to composite video out on Pin 9. Not sure how replacing this relates to csync on Pin 3, but I am getting the impression that I do not need to use the replacement resistor with the super CIC cysnc out. Can anyone help?
