No audio through hdmi
  • #59491
    Korgen
      I didn’t use my OSSC for a while. Yesterday I needed to use it, unfortunately I don’t have any audio through HDMI. It used to work but as I said it’s been a while and I can’t explain why the sound disapeared.
      My OSSC is 1.6 version. I made different tests, all of them result with no sound. I tried with
      – SNES and Amiga 1200 in AV1 input
      – different HDMI cables
      – different monitors (a TV and a PC monitor with speakers)
      – different firmwares (0.86a, 0.88a and 0.90a)
      The only way to have some audio is to plug a headset in A1 output :s
      Any help is appreciated.
      #59568
      Korgen
        Not a single reply within 24 hours in the official support forum…. great !!
        #59578
        Morpheus_79
          Korgen
            A broken chipset after 3 years and a few hours of utilisation ? What a mess…
            #59582
              That would be very unlikely unless hotplugging and bad luck were involved. Anyway, I’d recommend contacting the seller to see if warranty / repair is possible.
              #59588
              Korgen
                Bought on videogameperfection.com
                I doubt it’s still on warranty, I ordered it on december 2020. If an employee from this company comes here, let me know.
                • This reply was modified 1 year, 7 months ago by Korgen.
                #59596
                Morpheus_79
                  As ‘marqs’ wrote: it’s very unlikely… and i’ve never seen a broken U8 in the past (if i remember correctly) – but it’s possible. Sadly a few hours of utilisation won’t protect you from electronic components failing sometimes.
                  #59612
                    I’ve seen a handful go out of thousands of units sold. Usually due to hot plugging as others have said. If you’re in Europe we can attempt a repair for you, e-mail in for details.
