No audio with Toshiba 32LF221U19
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support No audio with Toshiba 32LF221U19
  • #25899
    kruuth
      I have my OSSC plugged into a 32 inch Toshiba 32LF221U19 and I am not getting audio. I tried this with the PS2, PS1, Genesis, etc. I’m using FW .82. Is there a way to fix this? I’ve tried setting the audio on the tv to PCM but that didn’t seem to change anything.
      #25900
        Are you using firmware 0.82 or 0.82a? Only the firmwares with the ‘a’/’-aud’ suffix have audio support.
        #25907
        kruuth
          It’s still not working. I’m using .82a now
          #25908
            You’re connecting to AV1 with scart cable?
            Audio works with different display?
            Have you tried different HDMI cable?
            #25909
            kruuth
              Using same HDMI cable that worked with previous unit.
              #25912
              Deleted User
                Is the OSSC set to output HDMI not DVI?
                Do you have Audio on the audio jack?
                The HDMI/DVI can be toggled in the settings.
                #25945
                kruuth
                  Not sure what I did but I reflashed .82-aud a second time and it seems to have fixed the issue.
