Hi All.
I have completed my soldering of the OSSC V1.5, and am experiencing an issue where there is no obvious signs of life in the device.
My power supply is providing a steady 5V, and is capable of delivering up to 2 amps if required.
I tested each of the 8 regulators on the board, and they are all behaving as expected – delivering their appropriate voltages, and only the middle pin being grounded.
Neither of the 2 fuses are blown, however strangely if I test the voltage at F2, I see 0.3V, when I would expect to see 5V!
Is there anything else I should be checking, what could be the cause of this?
I also started trying to debug U7 and U4 and couldn’t get my head around their behaviour.
U7 had 0.6V on the EN pin, meaning the regulator would not be turned on(it waits until EN hits >0.9V). However it appears the EN pin is connected to the VCC of U4. And U4 is connected only to the pin 13, 14 of the VGA connector! So how would that combination ever work? It looks like U4, drives the EN pin, however, it appears to be the VCC pin of U4 doing this, and surely – this is the power supply for the U4 pin. Perhaps I don’t understand the schmitt chip’s behaviour. This is a different topic to the main question, but it had me wondering as I was thinking things through.
Hopeful for any help and support, many thanks.
