No Sound from Hdmi
- This topic has 17 replies, 9 voices, and was last updated January 15, 2019 at 8:13 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › No Sound from Hdmi
You need to flick the switch that toggles AV1out/AV2in. It’s right next to the 3.5mm jack, semi-hidden (you’re far from the only one that missed it).
Wow didn’t see that switch, the unit works perfectly thanks. I was going crazy for a moment there. They should make that switch a different color.
Hi all I know this is an old topic and all but it came across my Google search for an answer. After spending quite a bit of time on this, I found a solution for some of you.
It all started when I switched TVs. Before, I would always get audio no problem from HDMI. However, when I got a new and better TV, I couldn’t hear audio anymore from HDMI. I fumbled for so long trying to fix it and eventually ended up going the analogue route like some of you and using the audio out jack. However, I really wanted to see if I could still get HDMI out and finally I figured it out.
You must go to:
Main Menu
Audio Options
Down Sampling
Select “fs = 48KHz”
After that, it worked. I don’t know whether this is the default setting or what, but it’s what I’m using now, and I hear Audio through HDMI once again. :]
