NTSC-J Japanese vs NTSC-J Hong Kong PS2 Hz timings
NewHome Forums General gaming NTSC-J Japanese vs NTSC-J Hong Kong PS2 Hz timings
  • #45756
    Thextera
      Hello there,
      recently discovered that a modded PAL PS2 console actually has a worse clockspeed than an NTSC Console.
      I checked this for Rayman 1 (PS1 game to be: 59.41hz on modded console compared to NTSC Console: 59.82hz
      Does anyone know if there is a difference between a NTSC-J console from Hong Kong & 1 from Japan ?
      The reason I’m wondering if it’s different is because in Hong Kong, they use 240V50hz standard for their power circuit whilest for Japan it’s not.
      I’m just wondering, if I can mod chip a NTSC-J Hong Kong PS2 and still get the same hertz as NTSC-J (Japan) and NTSC-US.
      I know there is this dfo dual frequency oscillator Mod you can do but I rather not bother with it.
      #45810
        All NTSC consoles have the same timings.
        #45819
        Thextera
          Is there a way to fix the timings on a mod chipped PAl console? To get 59.94 or 59.82 in my case specifcally.
          #46014
            On the PS2? Not sure, I know DFO works on PS1.
            #46985
            PoopDeck
              If you got access to homebrew like freemcboot you can use this to boot PS1 games in the correct video format.
              https://www.psx-place.com/resources/ps1vmodeneg-by-sp193.853/
              Not sure if this would help or not.
