OSSC 0.89 Settings on 0.90?
  • #54575
    Insert Disk Two
      I just ordered an OSSC and I was looking at generating my own .bin file with profiles using this site:
      http://pbnl.byethost7.com/ossc/profiles/
      Do 0.89 bins work with 0.90 because I don’t see a 0.90 option on the site.
      Which FW would the OSSC come flashed with?
      And, one last thing, can settings input directly on OSSC be exported to JSON?
      Thanks!
      #54593
        v0.89 profiles work on v0.90 firmware.
        Depends when and where the board has been bought. Probably not the latest one.
        They can be only exported to a .bin file on SD card, but I think you can drag&drop a .bin file on the box on that page as well.
        #54594
        Insert Disk Two
          Thanks for the reply!
          “Depends when and where the board has been bought. Probably not the latest one.”
          Ah sorry, I bought it from videogameperfection:)
          #54600
            As soon as you power on the board you can see f/w version on the LCD. It depends what was the latest when the batch was manufactured, but that was some time ago now so it won’t be the latest.
            #54621
            Insert Disk Two
              Great, thanks!
              #54631
              hi does anyone know how to rest the ossc back to factory setting as it came out of box
              #54632
              also i have a snes that has sound but no video when using my ossc can anyone help
              #54635
              Insert Disk Two
                Jeez get your own thread 🤣
                Joking… You probably need to install dejitter mod.
