OSSC 1.6 modified for 1.11a firmware
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC 1.6 modified for 1.11a firmware
  • #62702
    markesp
      Hello there.
      My OSSC is from mid 2021 so is a 1.6 revision board. Following the inclusion of Lumacode in the more recent firmware I decided to do the required modification to perform the update. Things are great, at least with my PC monitor, an LG 22″ circa 2010; Lumacode works wonderfully with my C64 and I’ve found some neat use cases for the new mask options in post proc and everything else works as it should.
      However, where previously the OSSC worked well with my lounge TV (Samsung UE50AU7100) there now seems to be an problem with compatibility.
      The OSSC syncs perfectly with the consoles I’ve tried so far (PAL Mega Drive with 60hz mod, Super Famicom with dejitter mod) and they mod work perfectly with the LG monitor, however the Samsung now struggles to sync with the OSSC, which wasn’t the case before I did the mod and updated the firmware.
      I’ve tried changing a bunch of settings but is there a compatibility setting I may need to change to get it working with this TV that I might have missed?
      #62750
        Try setting ADC PLL BW to low in sync options.
        #62762
        markesp
          Many thanks! Sorted! Respect due!
