OSSC 1.6 SNES Loses sync FW 0.81
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC 1.6 SNES Loses sync FW 0.81
  • #23276
    GumballBunny
      Edit 2: Anyone reading this if you too have issues with the snes losing sync on the latest firmware just change the TX mode to DVI. You’ll have to use a scart audio breakout adapter of some kind to get sound but its working fine for me. Assuming your tv works with the snes.
      Edit: Firmware 0.77 is the last firmware where snes works fine. My TV is a Vizio D40u-D1. Just to repeat on firmwares 0.77 and lower super nintendo runs flawlessly with no sync loss but updating to anything higher the snes will constantly lose sync. I have no idea why.
      So I’ve been troubleshooting this issue on my sd2snes. On a lower firmware 0.76 for example snes works fine with no sync drops. If I run the latest firmware it loses sync every 5 seconds and the audio is choppy as hell. All the settings are default nothing changed. It’s very weird.
      #23324
      HAN
        Having the exact same issue! My SNES Jr. is RGB modded with Voultar’s board, and worked great until the latest firmware. As it says in the video description, I don’t want to revert it back to the old firmware because my Neo Geo 1 slot couldn’t sync with it under the old firmware.
        I currently have no options to get sound via anything other than scart in my setup.
        #23856
        HAN
          Good news to anyone else who has this issue – the new .82a firmware seems to have corrected this issue entirely for me!
