OSSC 1080p settings
- This topic has 4 replies, 2 voices, and was last updated December 8, 2020 at 7:17 PM by .
NewHome › Forums › C64, C128 & ZX Spectrum Video Enhancement › OSSC 1080p settings
Greetings,
I’m struggling to get any output at all from my OSSC in 5x 1080p mode. I need to produce a good image for streaming and even though I do get the OSSC to output a signal that is 1080p and get my trial TV to display it it’s all black.
I get a display from the Copperdragon mod for 720×576 which I’m really happy about but alas my capture card does not accept that.
Anyone had luck with OSSC and 5x 1080p modes?
/Hravnkel
Your capture card won’t accept 576p?
Unfortunately not. It’s 720 or 1080 only.
3x mode should give you something in the ballpark of 720p, does that work?
I’m currently struggling a bit and will try to get it working. It’s a lot of info to take in with the more heavy tweaking. 😀 I’m also fairly certain that I will have to be bang on a standard CEA/VESA mode to find any success.
Not sure yet if it will be possible.
