OSSC 480p and Panasonic TC-P50S60
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC 480p and Panasonic TC-P50S60
  • #9682
    blitter
      Got my DIY OSSC up and running at the office and it spits out a gorgeous 480p signal to the Insignia NS-32D311NA15 TV on my desk. At home though, where I intend to have it permanently set up, I have a Panasonic TC-P50S60 and it does not recognize any signal from the OSSC at all– no test pattern, no picture from any of the inputs. I’ve tested it with a NESRGB, RGB N64, and SCART PS2, using firmwares 0.69, 0.70, 0.73, and the latest 0.74a, all with the same results at home. Looks like member deltronik has the same TV as me and got theirs working (https://videogameperfection.com/forums/reply/8069/) so I’d like to believe there’s some setting I can fiddle with on my unit to at least get the test pattern to show up. Any ideas? My wall-wart PSU is kicking out 5.37V under load so I doubt the PSU could be the cause, but honestly I’m at a loss– it could be anything.
      #9686
        No test pattern is extremely rare, have you checked your cabling?
        #9709
        blitter
          Yep– tried three different HDMI cables all known to work with other 1080p sources. No dice. 🙁
          #9719
            It sounds like you might have DDC5V signal disconnected from HDMI output, as some displays won’t display anything without that 5V status signal. I suggest checking that fuse F2 is okay and that HDMI pin18 is connected to other end of the fuse.
            #9727
            blitter
              Hi marqs, I checked my unit with no display connected– F2 is fine (no measurable resistance across it), pin 18 is carrying a solid 5V, and pin 15 is high.
              #9728
              blitter
                Just tested it against my SC512N1-L capture card, and I get the same results as on my Panny– no signal. Don’t know if that’s useful info but figured I’d relay it anyway.
                #10718
                blitter
                  Just wanted to report that I finally got my OSSC working on my Panasonic. Curiously, if I connect the OSSC directly to one of the HDMI inputs on my TV as described above, I get no picture. But if I run the OSSC first through a cheap passive HDMI selector switch, it works perfectly. Strange– maybe the switch “cleans up” the signal coming from the OSSC in some way? I can’t explain, but I can’t complain. 🙂
                  #10744
                    Definitely sounds like DDC5V and/or cabling problem.
                    #12197
                    lepo76
                      What kind of hdmi switch are you using, I may give that a go since I’m having exactly the same issue on my Panasonic Viera.
                      Tried 5 different hdmi cables and all hdmi ports… test pattern never shows up
                      (Ossc works fine on an hp pc monitor)
                      Thanks
                      #12208
                        Test pattern not showing on a monitor or capture card is an indication of damaged hardware. If you have a multimeter with a diode tester function on hand, try measuring (while OSSC is off and disconnected) forward voltage from ground (e.g. DVI chassis) to TMDS link1 and clock pins (8 total). You should measure 500-600mV in each pin if HDMI transmitter IC is undamaged.
                        #12220
                        lepo76
                          A friend of mine has a multi meter so hopefully we’ll manage to get some answers
                          I’ll report back once we are done. Thank you
                          #12246
                          lepo76
                            Haven’t checked with the multimeter yet but using a passive hdmi switcher, as reported by blitter, does something to the signal and the initial test pattern shows up, as expected. This makes two of us
                            Tested on two TV sets and got the same result
                            #12271
                            lepo76
                              Results from the multimeter test:
                              Pin 1 = 0.59mV and beeping while testing
                              Pin 2 = 154mV
                              Pin 9 = 519mV
                              Pin 10 = 519mV
                              Pin 17 = 520mV
                              Pin 18 = 200mV
                              Pin 23 = 519mV
                              Pin 24 = 519mV
