OSSC and Dreamcast+Hanzo
  • #12384
    blackice85
      Hi, I’m having some trouble with my Dreamcast. I have a Hanzo VGA box for the Dreamcast, but I can’t get it to work with the OSSC. I assume I’m doing something wrong, but wouldn’t the correct way to be from the Hanzo –> VGA cable –> VGA input on OSSC, and then select AV3 RGBHV on the OSSC? I have VGA selected on the Hanzo box as well, but I’ve also tried cycling through all settings and inputs that I can think of. The OSSC is on 0.76 and has the audio mod.
      Thanks
      #12400
        That’s the correct way yes, what exactly is happening?
        #12402
        blackice85
          I wasn’t getting it to sync at all and was starting to think it died somehow, but apparently I’m a moron. I had a loose cable despite rechecking everything multiple times, it’s working beautifully now. But thank you for the reply. =
