Hi all, so I bought a new ossc and have it set up and working with most of my consoles (snes, genesis, saturn, etc). But when I went to use my AES I apparently have a issue, and I have no idea how to fix it. When I turn on the AES it will display on the screen, the game will play fine, but I get a bunch of glitchy green lines that flash, coming from the right side of the screen. I am able to get rid of these lines by going to line 4x, but then screen cuts out to black every once in a while. It does this with a scart cable or the component cables. If it matters its a component modded AES, like those ones on ebay, I think REI or something. (not my first choice, I got it with a trade, but it worked great with my crt set up). I also noticed my omega mvs will also flash those glitchy green lines but eventually after about 10 seconds they go away, weird.
Any ideas what I need to do here to fix this? Both of these systems work fine, never had a problem with my old set up.
Appreciate any help, thanks!
