OSSC and PC monitor: 1440 or 4K?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC and PC monitor: 1440 or 4K?
  • #21332
    Galdelico
      Hi all,
      I’m currently using my OSSC coupled with a 1080p Asus monitor, which is great for all my retro needs, except for one thing: it manifests very limited scaling capabilities, so I get uneven scanlines in LineX4 mode.
      I previously owned a 4K monitor, which was perfect in that regard, due to its native resolution being multiple of 720p. Unfortunately, it was also an IPS diplay, so it turned out to be not the right choice for one like me, with a huge library of PAL PS2/GameCube/XBOX games.
      To my initial question, now: anyone here is using a 1440p monitor, just to confirm it’s equally fine (as it should, according to its native resolution) to 4K panels, to display even scanlines in LineX4, assuming the worst in terms of scaling features?
      Thanks in andvance!
      #21352
        My Dell 1440p monitor seems to work well with the OSSC but it’s my work monitor so I don’t use it a lot with OSSC.
        #21354
        Galdelico
          Do you mind to let me know the exact model, so I can check out its specs?
          Thanks ^_-
