I’m wondering if OSSC supports only a few, many or all (S)VGA resolutions? Does it allow to convert these to a target resolution – say, 1080p – with some aspect ratio settings/correction? There is very little documentation (or I can not find it) over the supported input (S)VGA resolutions and timings.
The problem is that (analog) VGA input is also becoming rare in displays (in addition to pal/ntsc RGB signals), and even if there is a VGA input in a device, it might not handle it properly.
Optimally, I’m looking for a device which can accept any (or at least most) resolutions a PC SVGA card can output, and convert it to HDMI, with options to convert the output resolution to a displays native resolution (1080p) *with* aspect ratio fixing, to work around stupid displays which have sub-optimal options built-in. I take it OSSC can not do this – it’s designed primarily for pal/ntsc and lower resolution signals?
Cheers!
P.s. My current projector does a very poor job for 4:3 resolutions over the HDMI input, and stretches everything to 16:9 *and* disables all aspect ratio options! It still does allow adjusting aspect ratio for any analog signal – which means, I can not use a digital output on a PC for non-16:9 resolutions, despite having a display adapter with this output. It seems it only allows to adjust aspect ratio for HDMI signals if they are 720p/i or 1080p/i, but for anything else over the HDMI, they will be stretched to 16:9 (despite being 4:3)!
So in this case, the analog conversion of the device is actually quite good, the problem is in how it handles HDMI signals. I’m looking something to future-proof retro-PC usage, in case my projector dies.
