OSSC capture from PVM
NewHome Forums General gaming OSSC capture from PVM
  • #47975
    CG1234
      I was curious if anyone here has ever used a OSSC to capture from a PVM?
      My setup is PS1 RGB Scart Male. Into a RGB Female Scart which leads to BNC RGB input of a 20M4U PVM.
      Then my idea is:
      BNC to RCA adapters on the PVM output.
      Component cable into the RGB output of the PVM.
      Component cable into the OSSC component input.
      HDMI into something like a Elgato hd60 S.
      USB from Elgato into my laptop with OBS Studio for recording.
      I hope this is clear, I tried to explain it the best I could.
      #47992
      CG1234
        So through some research. I found out I cannot capture component from the output of a PVM when using RGB input as the source.
        I’d have to use RGB output into the OSSC. Either by asking anyone from who personally has done this about it, or spending money until I find something that works.
        #48084
          Does the PVM support RGsB?, The OSSC does so that might work.
