i ended up figuring it out, i had the RGB offset Boosted to 150 on each color to brighten up the image on my CRT, this does work with Scart and VGA but i guess it conflicts with Component Video inputs
to resolve this you can just reset to default setting, if you need to brighten up your picture you can adjust the ADC Gain or each RGB Gain Value, unfortunately these will only brighten the picture so much before you start to lose detail but i figured i would mention it incase anyone else has my same use case scenario
