OSSC green led but nothing on the LCD display
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – DIY & Repair Support OSSC green led but nothing on the LCD display
Viewing 15 posts - 1 through 15 (of 18 total)
  • #14072
    vgdiy
      Hey all, I got back a few 1.6 OSSC pcbs fabricated and assembled. I successfully programed them using a JTAG usb blaster using 0.77 jic file. When I turn it off and then on again, the LCD display backlight and the red led flashes on briefly, then the display and red led turn off and the green led turns on solid. Any idea where to start troubleshooting?
      #14074
      Morpheus_79
        Did you see a test pattern, when you plug it to a screen or tv?
        #14080
        vgdiy
          No test pattern on the screen.
          #14081
            It sounds like JTAG cnnection to FPGA works and you can write flash, but on power-up FPGA cannot load the firmware. Did you have “verify” enabled while programming .jic, and did it report success? If that went fine, I’d next check that MSEL pins are connected correctly.
            #14085
            vgdiy
              the verify option was selected and the firmware reported success on completion. Ill take a look at the MSEL pins tomorrow.
              #14092
                Another thing to check is that FPGA properly gets 27MHz clock from the oscillator.
                #14093
                vgdiy
                  I just looked at pictures of my boards. the oscillator dot is not where the squared pin hole is. I have a feeling that is my problem. I will confirm tonight.
                  #14354
                  vgdiy
                    sorry for the delayed response, but fixing the oscillator fixed my problem.
                    #63847
                    Ideal1st
                      Hello everyone. It looks like that I have exact same problem, though I didn’t build the OSSC 1.6, but bought one ready made. Used it for some time. The unit was kept plugged in all the time. PSU is 5v 1.5a. Yesterday I tried to play some PS1 but got no image from OSSC though HDMI signal was detected by TV. I have power cycled the OSSC and it didn’t turn on anymore. LCD backlight flashes once being blank, red led blinks once and then green led is solid.
                      How can I troubleshoot?
                      #63856
                      Morpheus_79
                        You can check if the FPGA is working via JTAG connector and usb blaster. Since the problem sounds very similar to the one from the op you could check the oscillator via oscilloscope.
                        #63860
                        Ideal1st
                          I went for getting me a blaster to start with. After an attempt to reflash I will go looking for oscilloscope. How come the oscillator can become faulty after proving to be fully operational for some time?
                          #63864
                          Morpheus_79
                            Maybe it’s just a cold solder joint… maybe it’s a quality issue with the component.
                            But the assumption in this case is NOT: the oscillator is broken. It’s more or less: the FPGA doesn’t do anything – why is that? Could be a broken FPGA, or a broken oscillator,  or a broken flash, or a broken something else. Sometimes things simply break without an obvious reason.
                            #63939
                            Ideal1st
                              Well, I got my hands on the usb blaster and flashed the 0.90 to the OSSC
                              The thing didn’t boot up, so I tried reflashing. On my third attempt I got it booted up fine. I exhaled relaxed BUT!!! when I returned the thing to my TV rerouted all the cables it catched the same symptoms again. Screen blink then solid green…
                              Any ideas?
                              UPD: Back to the workbench I hooked the JTAG, powered on, got familiar “screen flash then solid green” and after around 30 seconds of standby powered on OSSC booted up! But eventually hanged… Now I am confused.
                              UPD2: Sometimes verification fails sometimes not:
                              Info (209060): Started Programmer operation at Fri Nov 1 22:29:51 2024
                              Info (209016): Configuring device index 1
                              Info (209017): Device 1 contains JTAG ID code 0x020F20DD
                              Info (209007): Configuration succeeded — 1 device(s) configured
                              Info (19845): Start Serial Flash Loader programming
                              Info (209018): Device 1 silicon ID is 0x14
                              Info (209044): Erasing ASP configuration device(s)
                              Info (209023): Programming device(s)
                              Info (209021): Performing CRC verification on device(s)
                              Error (209027): Verification failed for device number 1
                              Info (19845): End Serial Flash Loader programming
                              Error (209012): Operation failed
                              Info (209061): Ended Programmer operation at Fri Nov 1 22:30:29 2024
                              • This reply was modified 1 year, 8 months ago by Ideal1st.
                              #63945
                              Morpheus_79
                                Sadly those inconsistent faults are the hardest to find. Have you checked the oscillator?
                                #63946
                                Ideal1st
                                  I will take it to work tomorrow, they have an oscilloscope. (I never had experience with it) Shall I check if the oscillator outputs the required frequency?
