OSSC Grey Screen
  • #15324
    Leidsekade
      Hi all,
      My OSSC arrived this week and I’m having issues setting up.
      The image below shows my TV display with the OSSC plugged in.
      OSSC grey screen
      I have connected to the TV using HDMI out. I tested two separate TVs and consoles: Sega Saturn (PAL) with high quality SCART and Wii with official component cable. Same result each time.
      The OSSC’s LCD display just says Marqs and 0.78a firmware — no mention of signal/frequency etc. I don’t have the remote to test any further.
      Any help would be much appreciated.
      #15325
      Leidsekade
        Here’s the OSSC display:
        OSSC
        Thanks!
        #15326
        andychristian
          Have you tried cycling through the different input types? (the left button on the front of the OSSC) Usually just the one press switches to RGB Scart.
          #15327
          eric90000
            With the console/TV/OSSC powered on, try pressing the left button on the OSSC front buttons to toggle through the various inputs and see if you get a picture.
            #15328
              You have to select input (press button 0)
              Quick start guide is here http://junkerhq.net/xrgb/index.php?title=OSSC#Introduction
              Edit: i’m a slow poster… 😉
              #15336
              Leidsekade
                Yep, should’ve read the instructions more carefully. Thanks.
                #15588
                RandyFemrite
                  Thank YOU!
                  Now my Atari Jaguar looks better than ever.
