OSSC help Sega Dreamcast
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC help Sega Dreamcast
- This topic has 14 replies, 4 voices, and was last updated December 1, 2017 at 12:26 PM by
BuckoA51.
November 17, 2017 at 8:21 PM #17281
I just received my OSSC yesterday and I’m trying to hook it up to an LG OLED tv to test it out. I have a generic vga box that worked fine with my tv but now when I plug it into the OSSC with VGA cable and then output from HDMI to the tv, I just get the test pattern screen.
I made sure the input was set to AV3 RGBHV and I pushed info to see if I could find some more information. It appears it is outputting at a weird 1532×240 resolution and the Sync is off. The video LPF is set to Auto. I’m unsure if there’s something I’m doing wrong or if the vga box is just incompatible and I need to upgrade.
Any help would be greatly appreciated. Thank you.
November 17, 2017 at 9:56 PM #17283Dreamcast VGA boxes are much of a muchness. Can you tell us which Dreamcast you are using (PAL/NTSC) and the numbers it shows on the OSSCs LCD?
November 17, 2017 at 10:03 PM #17284Thanks for the response. It’s NTSC. I won’t be home until much later this evening so I cannot post the numbers just yet. I will take a picture. What menu did you want me to take the picture of?
Actually I managed to grab some pictures really quick.
November 18, 2017 at 12:27 AM #17292what’s on the standard read out, rather than the one you get when you hit info? Just “no sync” ?
November 18, 2017 at 5:53 AM #17297Yes. It just says AV3: RGBHV no sync.
November 19, 2017 at 4:08 PM #17324I guess try another VGA box then, but this is the first time I’ve heard of one being incompatible.
November 20, 2017 at 5:01 PM #17347Is there any that you recommend for better compatibility? I think I have one similar to the one by Retrobit (the picture looks the same as the one on Amazon).
November 21, 2017 at 8:18 PM #17387again I’m pretty stumped, VGA boxes for Dreamcast are basically just cables that short a few pins, so I’ve no idea why it’s not working for you. Did you try RGBS mode as well as RGBHV?
November 21, 2017 at 8:21 PM #17388Yes i cycled through all the modes just to see what would happen. At first I thought I just had it on the wrong input.
I can try it again. It’s the same vga box that’s pictured on amazon and labeled retrobit (it’s not a Retrobit but it looks exactly like the one that is pictured including the same label – DC VGA Box).
November 21, 2017 at 11:59 PM #17402Have you tried another device that outputs VGA to verify that the OSSC VGA input is working?
November 22, 2017 at 2:47 PM #17416Maybe check your VGA cable too, do you have another to test?
Ted.
November 22, 2017 at 4:48 PM #17420I appreciate all the suggestions. Here’s what I’ve tried:
1. Changed VGA cable, no change, everything reads the same.
2. Hooked up Xbox 360 via VGA cable and that works. It came up and read properly.I have a new VGA Dreamcast cable on the way and will test it once I have it in my hand.
November 30, 2017 at 3:44 AM #17672Great news. I finally got a Dreamcast VGA cable and hooked it up to the OSSC and it booted right up to the picture. Then I moved everything around, hooked it up again and had the same issue. So I unhooked everything and re-connected it and it has been working fine since. So, I’m assuming it was the VGA box? Unsure but everything looks great now.
December 1, 2017 at 12:26 PM #17704Perhaps the AV port on your Dreamcast has some damage? I managed to damage mine keep swapping between VGA and SCART back in the day.
