ossc hot during use
- This topic has 21 replies, 4 voices, and was last updated August 21, 2019 at 11:10 AM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › ossc hot during use
Which voltage point can I measured ? I will make a list of each point that you ask me to measure and we will see if all regulator are ok.
Edit : I don’t want to miss important voltage point. Marqs, can you tell me which voltage points are important to measure ?
I measured all voltage pins from regulator. This is values :
Pin n°_____1______2______3______4______5
U7:_______3.28____0_____5.15____0_____1.88
U9:_______3.28____0_____3.28____0_____1.88
U15/16:___3.28____0_____3.28____0_____1.79
U6:_______5.16____0_____5.16____0_____3.26
U12/14:___3.28____0_____3.28____0_____1.18
U13:______3.28____0_____3.28____0_____2.46
U5:______5.15____0_____3.29____0
What do you think about these values ? I find U13 strange with the 2.46V.
I suppose 5.15V on U7 pin 3 is typo (pin 1 and 3 are connected together), otherwise everything looks as should.
0.4A at 5.15V is perfectly normal, so the problem might be that digitizer and FPGA bottom ground/thermal pads are not soldered properly on PCB. If that is the case, heat transfer from those chips is bad which can create hotspots and eventually cause instability when their temperature rises high enough. The way to fix that would be reflowing/resoldering the ground pads on the bottom of the ICs, but if you’ve bought from VGP, you should just RMA the board.
Oh yes it’s typo. I recheck and yes pin 3 is 3.28V.
Yes I bought it from VGP but the warranty is over … Can I really return the OSSC to be repair or refund ? I’m not familiar with this kind of problem or return
What I need to send ? All I ordered so the remote too, my order number ? What’s the postal address of videogameperfection to return my OSSC ? When I bought it, VGP were in united kingdom and now there were in Ireland
So I contact VGP, because the warranty is over, they said I can’t RMA the OSSC. I’m very sad and disappointed. It’s a manufacturing error and not my fault. I just discovered this to late… And for me, the repair service is to expensive for me (for the moment) and mostly to just resolder each component…
Thank you @marqs for your help and your work again. I will continue to see your projects.
