OSSC Menus
- This topic has 3 replies, 2 voices, and was last updated June 13, 2019 at 4:31 PM by .
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Menus
Just got my OSSC and I’m overwhelmed with all of the menus. Are these all used when working with consoles or should I only be concerned about line scanning?
Normally you don’t need to touch anything, except possibly line multiplication (under Output Options), default is 2x so only 480p output.
Also I would recommend most users to try passthrough with their 480i/576i sources (default is linedoubled to 480p/576p), to see if it looks/feels better to them.
http://junkerhq.net/xrgb/index.php?title=OSSC
Yes, passthrough does look better there as I discovered with my PS2. I found a page that lists optimal timings for different systems. Do those make the picture any better on passthrough or only with line multiplication?
If you are overwhelmed by menus, then I would wait a bit with optimal modes.
Whether it looks better or worse is personal preference. I like the normal modes because with scanlines and some scaling by my display it looks more ”natural” (I tend to use x4 mode).
