Ossc no image/audio Ok
  • #15748
    n0rm_L
      I just received my ossc (firm 77a) and i’m not getting any image or video when i hook it up to my led tv.I’m getting audio though from the game.I’ve read the the wiki page and quick start guide for the ossc before hooking it up.I’m using a genesis 2 with a scart cable c sync(retrogaming cables uk) and a GE 40in LED LD-4055.I have the correct input on the ossc and i followed the troubleshooting guide for “NO IMAGE” and still nothing. I used the same console,game,scart cable on a framemeister and it works.What have i overlooked???
      #15750
        OSSC LED is green or red? What does it say on the display?
        #15754
        n0rm_L
          av1: RGBS 262P
          15.69kHz 59.91 Hz green light
          #15757
            Is the grey test pattern shown on the TV when you start the OSSC (before choosing input)? Also try another display if you can.
            #15759
            n0rm_L
              no grey test pattern, that’s the first thing i was looking for. I will test in another tv.
              #15767
              n0rm_L
                I only have one tv so i went to a friends house and tested it on an LG OLED.Test grey pattern shows up, and i have video now! Went thru all the settings and everything works.Problem solved! Time to get a new TV on black friday!!
                #15800
                skipkfc
                  Lucky for you, but may I suggest you test with other consoles as well and if your friend is okay with that.
                  I have tested with Supergun (HAS unit), CMVS, PC Engine (IFU with RGB modded), SNES and Famicom Twin (both RGB modded), only PC Engine and CMVS works, the rest received 262p. And I just bought the Sony X9000E recently!
                  #15805
                  n0rm_L
                    I only have the genesis 2 w/scart cable.As soon as i get my snes mini scart cable,i will test it.OOps, i forgot about the dreamcast, i’ll test that too.
                    #15807
                      Quite rare to not even get the test card, I know of only one other TV that does that IIRC.
