Ossc no sound hdmi
  • #43002
    Liamdrich86
      Apologies if this has been asked hundreds of times.
      I just bought a ossc it’s 1.6 model with hdmi, updated recently to latest 0.88a firmware, I simply get no sound.
      Setup is straight forward either PS2 or Dreamcast scart into the ossc and hdmi to TV,
      I checked the tx settings and that was correct and set to hdmi RGB
      I don’t have a 3.5m jack on TV but when I plug headphones into the 3.5m jack I get sound playing.
      I have swapped over the hdmi cable as well.
      Any ideas to help?
      Many thanks
      #43073
        Could you try a different TV?
        #43075
          Could be a solder issue I guess on the contacts to audio chip. But I don’t know how one would check that. You can always return it if it’s on warranty still.
          #43096
          Liamdrich86
            Have already tried another TV and same issue no audio.
            #43097
            Liamdrich86
              Sadly it was bought 2nd hand so no warranty
              #43106
                Did you verify it is a 1.6 model (in case the previous owner was mistaken)?
                #43113
                Liamdrich86
                  Def 1.6 older versions didn’t have hdmi model did they? Sticker on bottom of the device itself says 1.6 as well.
                  #43123
                    Oh right, I mixed up when they switched from DVI-D, sorry.
