OSSC Power cuts out, resets repeatedly
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – DIY & Repair Support OSSC Power cuts out, resets repeatedly
  • #65592
    Jonnypanic
      My OSSC 1.7 is constantly resetting. Sometimes if I leave it for a while and try again, it will work temporarily (about 30 mins) before shutting down and again getting stuck in what I think is a boot loop.
      It had worked fine since November when I got it, and only started doing this recently.
      I have tried changing the power supply to a usb barrel adapter and phone charger, and tried 3 different phone chargers, they all have the same issue as the original power supply.
      My OSSC is a generic Chinese one I bought on Amazon.
      I guess it could be an internal loose connection? Can anyone point me in the right direction, what should I be looking for?
      Thanks,
      JP
      #65614
        Sounds like cold solder joint or overheating. Resoldering all FPGA pins and/or adding better ventilation could help.
