OSSC Pro 0.76 Sound Bug in Capture Card
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro 0.76 Sound Bug in Capture Card
  • #63595
    Bratbatdeath
      Hi y have some trouble with the new update and the sound in my capture card, im using a El Gato 4k MK2 Capture Card, and before the new update works all fine, but after the 0,76 update sometimes the audio doesn’t play only in the capture card, but in the TV works fine, anyone have this problem, ought back to the previous firmware or have any FIX?
      #64676
        There should be audio related changes in v0.76. Does the issue still persist with v0.77?
        #64679
        Bratbatdeath
          The issue is partially fix in 0.77 but still sometimes when the ossc change resolutions the audio bug happens, y have to turn off the ossc pro and back on, to fix the audio not working on my capture card. In 0.76 happen every time and y had to reboot the ossc pro, in 0.77 is likely more uncommon, but sometimes still happens.
          #66416
          Bratbatdeath
            Y ask for help again in this issue, 0.78 and still having the sound problem with my ElGato GameCapture 4k MK2, anyone more having the issue?
            #66457
              Both the audio and audio metadata are sent out continuosly so the card should be able to restore audio after any interruption. It’s possible to add compatibility option for a longer HDMI handshake when a mode is changed which might help, though. Meanwhile, I’d recommend also to try to report the issue to Elgato support.
              #66463
              Bratbatdeath
                The issue is report to ElGato a while ago, basically the answer they gave me was that it is an unknown device for them and that I should contact the manufacturer of the device.
                Let’s say an almost automated response xD
                #67501
                Bratbatdeath
                  EDIT: y think this update works the issue, y don’t update to 0.80 y tryed and for the time been its working great, any anomalies i will report!
                  • This reply was modified 2 weeks, 4 days ago by Bratbatdeath.
