OSSC Pro – Advice on outputting 800×600 to a CRT tv
NewHome › Forums › OSSC, OSSC Pro and DExx-vd isl › OSSC – Discussion and support › OSSC Pro – Advice on outputting 800×600 to a CRT tv
- This topic has 7 replies, 4 voices, and was last updated March 22, 2026 at 8:33 PM by
rpgwaiter.
March 19, 2026 at 3:09 AM #68957
Just got the OSSC Pro, and I have a CRT monitor that takes VGA input. The monitor only works with 800×600@60 signals, and will display an error screen with any other.
I’m getting a feel for the OSSC Pro UX, but I don’t really understand how to force this resolution out of HDMI. My goal is to use an HDMI->VGA converter that should support this resolution, at least until the extra AV out boards are back in stock.
Anyways, how exactly do I set the OSSC Pro to output at this resolution? I’m testing with a PS2 over component cables but I’d eventually like to try a variety of consoles on this CRT.
This topic was modified 1 week, 6 days ago by
rpgwaiter.
March 19, 2026 at 8:52 AM #68962That would be very unusual to have a CRT monitor that could only do 800×600, most computer BIOS etc screens were not in that resolution. Anyway, you can use scaler mode to fix the output resolution to whatever you want.
March 19, 2026 at 10:06 AM #68963I figured that much. I can see a “PC 800x600_60” option under scaler opt -> adv. timing but I don’t see a way to actually enable that output
March 20, 2026 at 12:07 AM #68978Thats input timings. Scaler Opt->Scaler opt->DFP/CRT output mode lists available modes.
Really none of the available output modes work?
March 20, 2026 at 12:19 AM #68979No, the CRT really does only accept 800×600@60 for some reason. It’s a gateway monitor for some special PC (that I don’t own). Not sure why it has this restriction.
Edit: I’m not opposed to adding the new resolution myself and compiling my own firmware but I wanna make sure there isn’t another option first. If I do end up going that route I’ll submit a PR on GitHub.
This reply was modified 1 week, 5 days ago by
rpgwaiter.
March 21, 2026 at 9:05 AM #68984Is that truly a 38kHz capable tube? It looks like a standard 15kHz consumer CRT TV with maybe just a VGA card containing a TV encoder chip that downconverts 800×600 to SDTV. Anyway, you can repurpose any of the output presets (e.g. 1024x768_60) into 800x600_60 by just adjusting its timings (via Output opt -> Adv. disp timing) and then selecting it when using scaler mode.
March 22, 2026 at 1:45 PM #68995Those giant Gateway Destination monitors were sold as part of their short-lived attempt at making a PC the center of the living room. They reportedly have CRTs with coils for the 30-40 kHz range, so from what I understand they display 800×600@60 natively.
The little information available on them however suggests that they should handle most standard resolutions in that range, such as 640×480@60, but the model in question may be intentionally picky.
March 22, 2026 at 8:33 PM #68998 -
