OSSC Pro detecting PS3 as 90hz?
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro detecting PS3 as 90hz?
  • #58902
      Sat down to try some PS3 scaling tonight and noticed something strange, OSSC Pro seems to detect my PS3 Slim as outputting 90hz (89.91).
      This means it refuses to frame lock in scaler mode. In line multiplier mode it works, but still shows 89.91 hz on the information screen.
      Any ideas?
      90hz can't be right?
      #59113
        Vertical frequency is exactly 1.5x so I suspect your source sends Deepcolor (36bit) instead of normal 24bit. I should probably disable Deepcolor bit in EDID since the receiver anyway would convert it to 24bit.
        #59137
          I can confirm turning deep colour off solves the issue, I have to turn deep colour off on the PS3 and also power cycle the OSSC Pro.
          • This reply was modified 1 year, 10 months ago by BuckoA51.
