OSSC Pro Dreamcast VGA sync issues
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro Dreamcast VGA sync issues
  • #61326
    spacetime66
      Hi I’m having sync issues while hooking up Dreamcast via VGA to my OSSC Pro… I know the VGA cable is good as I’m able to get it the work without sync issues when going straight to PC CRT monitor and the OSSC Pro when using it with a HD15-2-SCART sync combiner via SCART… is there anyway to fix this with settings?
      I could use my HD15-2-SCART sync combiner to get Dreamcast to work flawlessly with OSSC Pro via SCART but I’d like to use my HD15-2-SCART for something else.
      Thanks in advance
      • This topic was modified 1 year, 3 months ago by spacetime66.
      #61328
        Can you elaborate, what issues exactly?
        #61329
          Try adjusting AV1-3 sync opt -> TTL Hsync Vth.
          #61330
          spacetime66
            Increasing TTL Hsync Vth in AV1-3 sync opt appears to have fixed the sync issue I was having
