OSSC Pro Extra Av out, Alternative for the AV input/output Adapter.
NewHome Forums OSSC, OSSC Pro and DExx-vd isl OSSC – Discussion and support OSSC Pro Extra Av out, Alternative for the AV input/output Adapter.
  • #66514
    Django Deters
      I was wondering if someone knows a good alternative for the AV input/output Adapter, since they are out of stock atm.
      My use case would be to connect the VGA from the Extra Av out board to a SCART input on a Consumer CRT TV (B&O MX6000)
      I’ve been looking around a bit for VGA to SCART cables and such, but getting a bit confused with all the Sync options and resistors etc.
      I did find some cables but don’t know if they would work for my purpose, as they seem to be for Mister FPGA use,
      Thanks in advance for responding.
      #66632
        Your safest bet would be a cable which has active sync combiner + 75ohm driver powered from VGA pin 9 or external 5V. The cable/adapter should bypass RGB lines without any additional circuitry. The AV in/out adapters are also back in stock although not in large quantity due to challenges sourcing scart connectors.
